Saltar al contenido principal
Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement
Qué necesitas
  1. Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: paso 2, imagen 1 de 3 Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: paso 2, imagen 2 de 3 Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: paso 2, imagen 3 de 3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 65
