Saltar al contenido principal
Milwaukee 6130-33 Safety Brush Springs Replacement
Qué necesitas
  1. Milwaukee 6130-33 Safety Brush Springs Replacement, Wiring System: paso 1, imagen 1 de 2 Milwaukee 6130-33 Safety Brush Springs Replacement, Wiring System: paso 1, imagen 2 de 2
    • Hold the device with the cord facing upwards and the bottom side facing down.
    • Remove the 4 mm TR20 Torx screws from the exterior case.
  2. Milwaukee 6130-33 Safety Brush Springs Replacement: paso 2, imagen 1 de 2 Milwaukee 6130-33 Safety Brush Springs Replacement: paso 2, imagen 2 de 2
    • Remove the two 4 mm TR20 Torx screws to detach the clamp from the cord set.
  3. Milwaukee 6130-33 Safety Brush Springs Replacement: paso 3, imagen 1 de 3 Milwaukee 6130-33 Safety Brush Springs Replacement: paso 3, imagen 2 de 3 Milwaukee 6130-33 Safety Brush Springs Replacement: paso 3, imagen 3 de 3
    • Remove the two 3.5 mm TR10 Torx screws to access the wiring.
    • Wiring can be damage or worn, take caution when handling the wires.
  4. Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: paso 4, imagen 1 de 3 Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: paso 4, imagen 2 de 3 Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: paso 4, imagen 3 de 3
    • Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
    • Turn over the device and perform the same process on the opposite side.
  5. Milwaukee 6130-33 Safety Brush Springs Replacement: paso 5, imagen 1 de 2 Milwaukee 6130-33 Safety Brush Springs Replacement: paso 5, imagen 2 de 2
    • Remove both springs by pulling outwards from the rotor.
    • When removing, pull on the carbon casing to avoid harming both yourself and the device.
  6. Milwaukee 6130-33 Safety Brush Springs Replacement: paso 6, imagen 1 de 2 Milwaukee 6130-33 Safety Brush Springs Replacement: paso 6, imagen 2 de 2
    • Using a pair of pliers, squeeze the black cord.
    • Remove by pulling the black wire attached to the brush casing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 56
