Saltar al contenido principal
Milwaukee 5262-21 Reduction Gear Assembly Replacement
Qué necesitas
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: paso 1, imagen 1 de 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: paso 3, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: paso 3, imagen 2 de 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 4, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 4, imagen 2 de 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 5, imagen 1 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 5, imagen 2 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 5, imagen 3 de 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 6, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 6, imagen 2 de 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 7, imagen 1 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 7, imagen 2 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 7, imagen 3 de 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 8, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 8, imagen 2 de 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 9, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 9, imagen 2 de 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 10, imagen 1 de 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 10, imagen 2 de 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 11, imagen 1 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 11, imagen 2 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 11, imagen 3 de 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 12, imagen 1 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 12, imagen 2 de 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: paso 12, imagen 3 de 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
Conclusión
Una persona más ha completado esta guía.
Payton Parker
Miembro Desde 03/08/19
534 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 1,320
