Saltar al contenido principal
Milwaukee 5262-21 Power Cord Replacement
Qué necesitas
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: paso 1, imagen 1 de 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: paso 3, imagen 1 de 2 Milwaukee 5262-21 Power Cord Replacement, Power Cord: paso 3, imagen 2 de 2
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: paso 4, imagen 1 de 3 Milwaukee 5262-21 Power Cord Replacement: paso 4, imagen 2 de 3 Milwaukee 5262-21 Power Cord Replacement: paso 4, imagen 3 de 3
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: paso 5, imagen 1 de 3 Milwaukee 5262-21 Power Cord Replacement: paso 5, imagen 2 de 3 Milwaukee 5262-21 Power Cord Replacement: paso 5, imagen 3 de 3
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
Conclusión
Adrien Andrade-Cain
Miembro Desde 03/08/19
181 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 292
