Saltar al contenido principal
Milwaukee 5262-21 Motor Housing Replacement
Qué necesitas
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: paso 1, imagen 1 de 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: paso 2, imagen 1 de 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: paso 3, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: paso 3, imagen 2 de 2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: paso 4, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 4, imagen 2 de 2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: paso 5, imagen 1 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 5, imagen 2 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 5, imagen 3 de 3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: paso 6, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 6, imagen 2 de 2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: paso 7, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 7, imagen 2 de 2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: paso 8, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 8, imagen 2 de 2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: paso 9, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: paso 9, imagen 2 de 2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: paso 10, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 10, imagen 2 de 2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: paso 11, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 11, imagen 2 de 2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: paso 12, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 12, imagen 2 de 2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: paso 13, imagen 1 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 13, imagen 2 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 13, imagen 3 de 3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: paso 14, imagen 1 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 14, imagen 2 de 3 Milwaukee 5262-21 Motor Housing Replacement: paso 14, imagen 3 de 3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: paso 15, imagen 1 de 2 Milwaukee 5262-21 Motor Housing Replacement: paso 15, imagen 2 de 2
    • Remove the motor housing from the device.
Conclusión
Andrew Floyd
Miembro Desde 03/08/19
277 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 283
