Saltar al contenido principal
Milwaukee 2704-20 Trigger Replacement
Qué necesitas
  1. Milwaukee 2704-20 Trigger Replacement, Outer Case: paso 1, imagen 1 de 2 Milwaukee 2704-20 Trigger Replacement, Outer Case: paso 1, imagen 2 de 2
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Trigger Replacement: paso 2, imagen 1 de 3 Milwaukee 2704-20 Trigger Replacement: paso 2, imagen 2 de 3 Milwaukee 2704-20 Trigger Replacement: paso 2, imagen 3 de 3
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Trigger Replacement: paso 3, imagen 1 de 3 Milwaukee 2704-20 Trigger Replacement: paso 3, imagen 2 de 3 Milwaukee 2704-20 Trigger Replacement: paso 3, imagen 3 de 3
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Trigger Replacement, Trigger: paso 4, imagen 1 de 2 Milwaukee 2704-20 Trigger Replacement, Trigger: paso 4, imagen 2 de 2
    • Desolder the two solder joints on the trigger assembly.
    • USE CAUTION! Soldering irons get extremely hot, as will everything they make prolonged contact with.
  5. Milwaukee 2704-20 Trigger Replacement: paso 5, imagen 1 de 2 Milwaukee 2704-20 Trigger Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the header connector.
    • To avoid damage, be careful replicating this step in both the removal and replacement processes.
  6. Milwaukee 2704-20 Trigger Replacement: paso 6, imagen 1 de 1
    • Remove the trigger mechanism entirely.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 346
