Saltar al contenido principal
Milwaukee 2704-20 Control Switch Replacement
Qué necesitas
  1. Milwaukee 2704-20 Control Switch Replacement, Outer Case: paso 1, imagen 1 de 2 Milwaukee 2704-20 Control Switch Replacement, Outer Case: paso 1, imagen 2 de 2
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Control Switch Replacement: paso 2, imagen 1 de 3 Milwaukee 2704-20 Control Switch Replacement: paso 2, imagen 2 de 3 Milwaukee 2704-20 Control Switch Replacement: paso 2, imagen 3 de 3
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Control Switch Replacement: paso 3, imagen 1 de 3 Milwaukee 2704-20 Control Switch Replacement: paso 3, imagen 2 de 3 Milwaukee 2704-20 Control Switch Replacement: paso 3, imagen 3 de 3
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Control Switch Replacement, Control Switch: paso 4, imagen 1 de 3 Milwaukee 2704-20 Control Switch Replacement, Control Switch: paso 4, imagen 2 de 3 Milwaukee 2704-20 Control Switch Replacement, Control Switch: paso 4, imagen 3 de 3
    • Remove the control switch.
    • It is not attached to anything and should slide out easily. Take note of orientation and be sure to replace it in the same position.
Conclusión
Unique Linnell
Miembro Desde 03/13/23
423 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 390
