Saltar al contenido principal
Mill Cutter Paper Stripper Replacement
Qué necesitas
  1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: paso 1, imagen 1 de 1
    • Unplug the shredder from the wall electrical outlet.
    • Remove the shredder from its catch basket and place it face down on a flat surface.
  2. Mill Cutter Paper Stripper Replacement: paso 2, imagen 1 de 3 Mill Cutter Paper Stripper Replacement: paso 2, imagen 2 de 3 Mill Cutter Paper Stripper Replacement: paso 2, imagen 3 de 3
    • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
    • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
  3. Mill Cutter Paper Stripper Replacement: paso 3, imagen 1 de 2 Mill Cutter Paper Stripper Replacement: paso 3, imagen 2 de 2
    • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
  4. Mill Cutter Paper Stripper Replacement: paso 4, imagen 1 de 2 Mill Cutter Paper Stripper Replacement: paso 4, imagen 2 de 2
    • Once all of the screws have been removed, pull the casing apart.
    • Remove the stripper guide from the housing unit.
    • Use caution to prevent the trigger guard from falling apart.
  5. Mill Cutter Paper Stripper Replacement: paso 5, imagen 1 de 3 Mill Cutter Paper Stripper Replacement: paso 5, imagen 2 de 3 Mill Cutter Paper Stripper Replacement: paso 5, imagen 3 de 3
    • Remove the e-clips from the gears on the left side with a flathead screwdriver.
    • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
  6. Mill Cutter Paper Stripper Replacement: paso 6, imagen 1 de 3 Mill Cutter Paper Stripper Replacement: paso 6, imagen 2 de 3 Mill Cutter Paper Stripper Replacement: paso 6, imagen 3 de 3
    • Remove the gears from both sides.
    • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
    • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
  7. Mill Cutter Paper Stripper Replacement: paso 7, imagen 1 de 2 Mill Cutter Paper Stripper Replacement: paso 7, imagen 2 de 2
    • Replace the mill cutter paper stripper set and stripper guide set.
    • Use protective gloves as the blades are very sharp.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,334
