Qué necesitas
The detergent drawer is removed, push down the yellow lever to remove it completely.
The left side panel has three clearly visible screws at the top and three at the back, all Tx20. These must be removed. Caution, the three screws above are only identical to the bottom screw at the back, the other two screws from the back are different.
Caution, the side panel cannot be removed yet, in this step only loosen the screws.
Now move the front a bit so that you can loosen the 3 Tx20 screws on the left front. Then reinsert the front panel and fix it with the two upper screws. The left front can now be removed. Attention when installing the left front later, it will be hooked in at the lower end.
Be careful when installing the left side cover later, it will be slightly hooked at the lower end.
Work the steps in reverse order to reassemble your device.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
