Introducción
This guide will go over disassembling the back panel of the Midiman Oxygen 8 Keyboard, allowing you to access the rest of the internal components. This is a Prerequisite guide.
Qué necesitas
Remove the 8 mm M3 Phillips head self tapping machine screws.
Remove all 13 of the back plate screws.
Removal of Ribbon Cables
To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
