Saltar al contenido principal
Midiman Oxygen 8 Backplate Disassembly
Qué necesitas
  1. Midiman Oxygen 8 Backplate Disassembly, Midiman Oxygen 8 Backplate Disassembly: paso 1, imagen 1 de 2 Midiman Oxygen 8 Backplate Disassembly, Midiman Oxygen 8 Backplate Disassembly: paso 1, imagen 2 de 2
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
  2. Midiman Oxygen 8 Backplate Disassembly: paso 2, imagen 1 de 2 Midiman Oxygen 8 Backplate Disassembly: paso 2, imagen 2 de 2
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
  3. Midiman Oxygen 8 Backplate Disassembly: paso 3, imagen 1 de 3 Midiman Oxygen 8 Backplate Disassembly: paso 3, imagen 2 de 3 Midiman Oxygen 8 Backplate Disassembly: paso 3, imagen 3 de 3
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
  4. Midiman Oxygen 8 Backplate Disassembly: paso 4, imagen 1 de 2 Midiman Oxygen 8 Backplate Disassembly: paso 4, imagen 2 de 2
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
Conclusión
Alexander Heitzman
Miembro Desde 10/05/16
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-6, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 361
