Saltar al contenido principal
Mid F900 Speaker Replacement
Qué necesitas
  1. Mid F900 Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: paso 2, imagen 1 de 2 Mid F900 Speaker Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: paso 4, imagen 1 de 1
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
Conclusión
Jacques Pierre
Miembro Desde 09/07/16
336 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-6, Remmell Fall 2016 Miembro de USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 143
