Saltar al contenido principal
Mid F900 Motherboard Replacement
Qué necesitas
  1. Mid F900 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Motherboard Replacement: paso 2, imagen 1 de 2 Mid F900 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 2 Mid F900 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Motherboard Replacement: paso 4, imagen 1 de 2 Mid F900 Motherboard Replacement: paso 4, imagen 2 de 2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Motherboard Replacement: paso 5, imagen 1 de 2 Mid F900 Motherboard Replacement: paso 5, imagen 2 de 2
    • Carefully lift and remove the motherboard from the device housing.
Conclusión
Matthew Oliva
Miembro Desde 09/10/16
364 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 6-6, Remmell Fall 2016 Miembro de USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 313
