Saltar al contenido principal
Microtek ScanMaker 5900 Stepper Motor Replacement
Qué necesitas
  1. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: paso 1, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: paso 1, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: paso 1, imagen 3 de 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: paso 2, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: paso 2, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: paso 2, imagen 3 de 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: paso 3, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: paso 3, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: paso 3, imagen 3 de 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: paso 4, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: paso 4, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: paso 4, imagen 3 de 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: paso 5, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: paso 5, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: paso 5, imagen 3 de 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: paso 6, imagen 1 de 2 Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: paso 6, imagen 2 de 2
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Microtek ScanMaker 5900 Stepper Motor Replacement: paso 7, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement: paso 7, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement: paso 7, imagen 3 de 3
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Microtek ScanMaker 5900 Stepper Motor Replacement: paso 8, imagen 1 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement: paso 8, imagen 2 de 3 Microtek ScanMaker 5900 Stepper Motor Replacement: paso 8, imagen 3 de 3
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 6-9, Regan Fall 2011 Miembro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,599
