Saltar al contenido principal
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
Qué necesitas
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: paso 1, imagen 1 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: paso 1, imagen 2 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: paso 1, imagen 3 de 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: paso 2, imagen 1 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: paso 2, imagen 2 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: paso 2, imagen 3 de 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: paso 3, imagen 1 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: paso 3, imagen 2 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: paso 3, imagen 3 de 3
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: paso 4, imagen 1 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: paso 4, imagen 2 de 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: paso 4, imagen 3 de 3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: paso 5, imagen 1 de 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: paso 5, imagen 2 de 2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
Conclusión
Taylor Nesheim
Miembro Desde 10/11/11
59 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 6-9, Regan Fall 2011 Miembro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,149
