Saltar al contenido principal
Microsoft Zune HD Lower Rear Panel Replacement
Qué necesitas
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: paso 1, imagen 1 de 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: paso 2, imagen 1 de 2 Microsoft Zune HD Lower Rear Panel Replacement: paso 2, imagen 2 de 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: paso 3, imagen 1 de 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: paso 3, imagen 2 de 2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: paso 4, imagen 1 de 1
    • Carefully slide the lower rear panel away from the Zune.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 3,132
