Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Removal of case backing, allowing for access to internal components.
  1. Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. There are two T4 screws under the cap. Remove both with a T4 screwdriver.
    • There are two T4 screws under the cap. Remove both with a T4 screwdriver.
    • Be careful removing the screws; the screw heads can break very easily.
  3. Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Conclusión
turey
Miembro Desde 11/11/09
333 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-5, Maness Fall 2009 Miembro de Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 4,011
