Saltar al contenido principal
Microsoft Zune 30 GB Battery Replacement
Qué necesitas
  1. Microsoft Zune 30 GB Battery Replacement, Back Case: paso 1, imagen 1 de 2 Microsoft Zune 30 GB Battery Replacement, Back Case: paso 1, imagen 2 de 2
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
  2. Microsoft Zune 30 GB Battery Replacement: paso 2, imagen 1 de 1
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
  3. Microsoft Zune 30 GB Battery Replacement: paso 3, imagen 1 de 2 Microsoft Zune 30 GB Battery Replacement: paso 3, imagen 2 de 2
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
  4. Microsoft Zune 30 GB Battery Replacement, Battery: paso 4, imagen 1 de 2 Microsoft Zune 30 GB Battery Replacement, Battery: paso 4, imagen 2 de 2
    • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
    • Use the small flat head screw driver to gently lift the brown clamp.
    • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
  5. Microsoft Zune 30 GB Battery Replacement: paso 5, imagen 1 de 1
    • You can now replace the battery.
    • The battery is a Lithium ion 3.7 V.
Conclusión
19 personas más completaron esta guía.
jmorri04
Miembro Desde 10/16/09
275 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 19-4, Maness Fall 2009 Miembro de Cal Poly, Team 19-4, Maness Fall 2009
CPSU-MANESS-F09S19G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 91
Todo El Tiempo: 16,941
