Saltar al contenido principal
Microsoft Surface Pro Kickstand Replacement
Qué necesitas
  1. Microsoft Surface Pro Kickstand Replacement, Kickstand: paso 1, imagen 1 de 1
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws:
    • One from the left hinge
    • One from the right hinge
  2. Microsoft Surface Pro Kickstand Replacement: paso 2, imagen 1 de 1
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
Conclusión
7 personas más completaron esta guía.
Mark
Miembro Desde 10/09/13
624 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-20, Regan Fall 2013 Miembro de Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Miembros
13 Guías creadas
Un comentario
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 132
Todo El Tiempo: 37,075
