Saltar al contenido principal
Introducción
The kickstand of your Microsoft Surface Pro 5 is a convenient feature of the device, but if it breaks off or stops holding your tablet upright, you may want to replace it. Follow this guide to replace the kickstand of your Microsoft Surface Pro 5. This is a quick and easy repair that will greatly improve the usability of the Surface Pro 5.
  1. Microsoft Surface Pro 5 Kickstand Replacement, Kickstand: paso 1, imagen 1 de 3 Microsoft Surface Pro 5 Kickstand Replacement, Kickstand: paso 1, imagen 2 de 3 Microsoft Surface Pro 5 Kickstand Replacement, Kickstand: paso 1, imagen 3 de 3
    • Lift the kickstand about 90º to reveal the hinges.
  2. Microsoft Surface Pro 5 Kickstand Replacement: paso 2, imagen 1 de 2 Microsoft Surface Pro 5 Kickstand Replacement: paso 2, imagen 2 de 2
    • Remove the four 2.7 mm T3 Torx screws, two from each hinge.
  3. Microsoft Surface Pro 5 Kickstand Replacement: paso 3, imagen 1 de 2 Microsoft Surface Pro 5 Kickstand Replacement: paso 3, imagen 2 de 2
    • Lower the kickstand to about a 15-30º angle from the device.
    • Gently pull the kickstand away from the device, rocking left to right to disengage the adhesive tabs connecting the kickstand to the device.
    • During reassembly, be sure to reinsert the two adhesive tabs into the slots on the back of the device before installing the screws in the hinges.
Conclusión
Una persona más ha completado esta guía.
Sarah Westberg
Miembro Desde 11/03/19
15,958 Reputación
65 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
146 Miembros
16,069 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 30
Ultimos 30 días: 150
Todo El Tiempo: 4,785
