Introducción
This guide will teach you how to safely remove your rear camera from you Surface Pro 3. The guide starts by removing the screen and digitizer and then goes right into removing the rear-facing camera.
Herramientas
Partes
No se especificaron partes.
To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
Remove the 4mm screw with the T3 Torx Screwdriver.
Remove the four 7mm screws with the T3 Torx Screwdriver.
2 personas más completaron esta guía.
