Saltar al contenido principal
Microsoft Surface Pro 2 Audio Ports Replacement
Qué necesitas
  1. Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: paso 1, imagen 1 de 2 Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: paso 1, imagen 2 de 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Audio Ports Replacement: paso 2, imagen 1 de 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Audio Ports Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Audio Ports Replacement: paso 4, imagen 1 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 4, imagen 2 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 4, imagen 3 de 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: paso 5, imagen 1 de 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: paso 5, imagen 2 de 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: paso 5, imagen 3 de 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Audio Ports Replacement: paso 6, imagen 1 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 6, imagen 2 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 6, imagen 3 de 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Audio Ports Replacement: paso 7, imagen 1 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 7, imagen 2 de 3 Microsoft Surface Pro 2 Audio Ports Replacement: paso 7, imagen 3 de 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
  8. Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: paso 8, imagen 1 de 2 Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: paso 8, imagen 2 de 2
    • The entire assembly can be removed by taking out one final screw.
    • These screws as well as the ribbon were removed during the perquisite guide for removing the motherboard.
Conclusión
Mathew B
Miembro Desde 09/19/16
323 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-2, Remmell Fall 2016 Miembro de USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,299
