Saltar al contenido principal
Microsoft Surface Pen Tip Replacement
Qué necesitas
  1. Microsoft Surface Pen Tip Replacement, Tip: paso 1, imagen 1 de 3 Microsoft Surface Pen Tip Replacement, Tip: paso 1, imagen 2 de 3 Microsoft Surface Pen Tip Replacement, Tip: paso 1, imagen 3 de 3
    • Order the Microsoft Surface Pen tip replacement kit.
    • Hold your pen at an angle and unscrew the top part of the pen.
  2. Microsoft Surface Pen Tip Replacement: paso 2, imagen 1 de 3 Microsoft Surface Pen Tip Replacement: paso 2, imagen 2 de 3 Microsoft Surface Pen Tip Replacement: paso 2, imagen 3 de 3
    • Extract the tip now that it is fully exposed.
    • When you extract the tip, make sure don't do it too hard. The inside of the pen can be broken.
  3. Microsoft Surface Pen Tip Replacement: paso 3, imagen 1 de 3 Microsoft Surface Pen Tip Replacement: paso 3, imagen 2 de 3 Microsoft Surface Pen Tip Replacement: paso 3, imagen 3 de 3
    • After you extract the tip, roll the tissue on toothpick.
    • I recommend cutting the tissue in half.
  4. Microsoft Surface Pen Tip Replacement: paso 4, imagen 1 de 3 Microsoft Surface Pen Tip Replacement: paso 4, imagen 2 de 3 Microsoft Surface Pen Tip Replacement: paso 4, imagen 3 de 3
    • Clean the inside of the top detachable part of the pen with a toothpick covered with tissue.
    • Make sure there is no residue on the edge.
  5. Microsoft Surface Pen Tip Replacement: paso 5, imagen 1 de 3 Microsoft Surface Pen Tip Replacement: paso 5, imagen 2 de 3 Microsoft Surface Pen Tip Replacement: paso 5, imagen 3 de 3
    • Choose the tip that you would like to use and insert in a hole.
  6. Microsoft Surface Pen Tip Replacement: paso 6, imagen 1 de 3 Microsoft Surface Pen Tip Replacement: paso 6, imagen 2 de 3 Microsoft Surface Pen Tip Replacement: paso 6, imagen 3 de 3
    • Screw the detachable part of the pen back on.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 48
Todo El Tiempo: 6,607
