Saltar al contenido principal
Microsoft Surface Headphones Speaker Replacement
Qué necesitas
  1. Microsoft Surface Headphones Speaker Replacement, Ear Cushion: paso 1, imagen 1 de 1
    • Firmly grasp the ear cushions, and rotate them counterclockwise about 45 degrees, or until you hear a "click."
    • Be careful not to use excessive force during rotation.
  2. Microsoft Surface Headphones Speaker Replacement: paso 2, imagen 1 de 1
    • Lift the ear cushions off the speaker housings.
  3. Microsoft Surface Headphones Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Microsoft Surface Headphones Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Remove the six 2.6mm screws with a Phillips #00 screwdriver, and gently lift the speaker housings away.
    • If only one of the speakers is malfunctioning, only remove the screws on the affected side, and leave the functional speaker intact.
  4. Microsoft Surface Headphones Speaker Replacement: paso 4, imagen 1 de 2 Microsoft Surface Headphones Speaker Replacement: paso 4, imagen 2 de 2
    • Gently pry the speaker housing away from the chassis with a spudger.
  5. Microsoft Surface Headphones Speaker Replacement: paso 5, imagen 1 de 1
    • Desolder the speaker's motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
Conclusión
2 personas más completaron esta guía.
5 comentarios
How can I get my turtle Beach to pair
Miguel Garcia - Contestar
How do I remove the speaker from the plastic housing? Is it glued in place? I desoldered the speaker unit and now I am trying to take out speaker from its housing.
Stephen Hyland - Contestar
I would also like to know this! replacing the speaker requires the plastic housing to be opened. I tried heating the housing with a hair dryer but no result....
fixer8888 -
I cut it in half down the side. Very long a tedious process. also makes it hard to get a tight seal for reassembly but with a little more patience than I had and a clamp to glue the pieces together could probably get a nice finish. I have a gap which causes a little weirdness for the ANC especially with wind.
joshray -
Where do you get replacement speaker
marilyn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 57
Todo El Tiempo: 1,776
