Introducción
A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
  1. A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  2. Use the flat end of a spudger to pop the keys off the keyboard.
    • Use the flat end of a spudger to pop the keys off the keyboard.
    • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
    • Continue removing keys.
    • Remove the 10 screws from the bottom of the keyboard.
    • Remove the upper button assembly.
    • Use the tip of a spudger to push the upper button assembly buttons out from the back.
    • Remove the flexible keypad from the key caddy assembly.
    • The key caddies can be washed in the sink.
    • The keys can also be washed.
    • Remove the metal retaining clips before washing to prevent rust.
Conclusión
6 personas más completaron esta guía.
asvnix
Miembro Desde 18/11/12
220 Reputación
1 Guía escrita
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 31
Últimos 30 Días: 123
Todo El Tiempo: 7,787
