Saltar al contenido principal
Microsoft Lumia 640 XL Motherboard Replacement
Qué necesitas
  1. Microsoft Lumia 640 XL Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Microsoft Lumia 640 XL Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Microsoft Lumia 640 XL Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Motherboard Replacement: paso 2, imagen 1 de 2 Microsoft Lumia 640 XL Motherboard Replacement: paso 2, imagen 2 de 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: paso 3, imagen 1 de 3 Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: paso 3, imagen 2 de 3 Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: paso 3, imagen 3 de 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Motherboard Replacement: paso 4, imagen 1 de 3 Microsoft Lumia 640 XL Motherboard Replacement: paso 4, imagen 2 de 3 Microsoft Lumia 640 XL Motherboard Replacement: paso 4, imagen 3 de 3
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Microsoft Lumia 640 XL Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Motherboard Replacement: paso 6, imagen 1 de 3 Microsoft Lumia 640 XL Motherboard Replacement: paso 6, imagen 2 de 3 Microsoft Lumia 640 XL Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
Conclusión
2 personas más completaron esta guía.
Un comentario
Thanks, It was super
Yasmany - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 678
