Saltar al contenido principal
Microsoft Lumia 640 XL Headphone Jack Replacement
Qué necesitas
  1. Microsoft Lumia 640 XL Headphone Jack Replacement, Battery: paso 1, imagen 1 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement, Battery: paso 1, imagen 2 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement, Battery: paso 1, imagen 3 de 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Headphone Jack Replacement: paso 2, imagen 1 de 2 Microsoft Lumia 640 XL Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Headphone Jack Replacement, Headphone Jack: paso 3, imagen 1 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement, Headphone Jack: paso 3, imagen 2 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement, Headphone Jack: paso 3, imagen 3 de 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Headphone Jack Replacement: paso 4, imagen 1 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement: paso 4, imagen 2 de 3 Microsoft Lumia 640 XL Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 253
