Saltar al contenido principal
Microsoft Lumia 435 Touch screen Glass Only Replacement
Qué necesitas
Resumen del Video
  1. Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: paso 1, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: paso 1, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 2, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 2, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 2, imagen 3 de 3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: paso 3, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: paso 3, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: paso 3, imagen 3 de 3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 4, imagen 1 de 2 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 4, imagen 2 de 2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: paso 5, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: paso 5, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: paso 5, imagen 3 de 3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 6, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 6, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 6, imagen 3 de 3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 7, imagen 1 de 1
    • The display is very fragile, do the separation very carefully.
  8. Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: paso 8, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: paso 8, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: paso 8, imagen 3 de 3
    • Put some transparent scotch tape to prevent the glass from shattering.
    • Warm the glass for a minute to make adhesive soften.
    • Start the separation from the middle of the frame, where the contact area is smaller.
  9. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 9, imagen 1 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 9, imagen 2 de 3 Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 9, imagen 3 de 3
    • When you finished with the separation the glass, clean the frame from the old adhesive.
    • Install the new touch screen and start to reassemble the device.
  10. Microsoft Lumia 435 Touch screen Glass Only Replacement: paso 10, imagen 1 de 1
    • That's all.
Conclusión
5 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
Un comentario
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
Addison Ramsey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 5,301
