Saltar al contenido principal
Microsoft Lumia 435 Logic board Replacement
Qué necesitas
Resumen del Video
  1. Microsoft Lumia 435 Logic board Replacement, Back Cover: paso 1, imagen 1 de 3 Microsoft Lumia 435 Logic board Replacement, Back Cover: paso 1, imagen 2 de 3 Microsoft Lumia 435 Logic board Replacement, Back Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 Logic board Replacement: paso 2, imagen 1 de 3 Microsoft Lumia 435 Logic board Replacement: paso 2, imagen 2 de 3 Microsoft Lumia 435 Logic board Replacement: paso 2, imagen 3 de 3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 Logic board Replacement, Logic board: paso 3, imagen 1 de 3 Microsoft Lumia 435 Logic board Replacement, Logic board: paso 3, imagen 2 de 3 Microsoft Lumia 435 Logic board Replacement, Logic board: paso 3, imagen 3 de 3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 Logic board Replacement: paso 4, imagen 1 de 2 Microsoft Lumia 435 Logic board Replacement: paso 4, imagen 2 de 2
    • This is the logic board / main board - a front and rear view.
Conclusión
5 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,308 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,534 Guías creadas
2 comentarios
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Contestar
I need dead boatd off lumia 435
Azhar from lahore chung
Muhammad Azhar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,785
