Saltar al contenido principal
Microsoft Lumia 435 LCD Display Replacement
Qué necesitas
Resumen del Video
  1. Microsoft Lumia 435 LCD Display Replacement, Back Cover: paso 1, imagen 1 de 3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: paso 1, imagen 2 de 3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 LCD Display Replacement: paso 2, imagen 1 de 3 Microsoft Lumia 435 LCD Display Replacement: paso 2, imagen 2 de 3 Microsoft Lumia 435 LCD Display Replacement: paso 2, imagen 3 de 3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 LCD Display Replacement, Logic board: paso 3, imagen 1 de 3 Microsoft Lumia 435 LCD Display Replacement, Logic board: paso 3, imagen 2 de 3 Microsoft Lumia 435 LCD Display Replacement, Logic board: paso 3, imagen 3 de 3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 LCD Display Replacement: paso 4, imagen 1 de 2 Microsoft Lumia 435 LCD Display Replacement: paso 4, imagen 2 de 2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 LCD Display Replacement, LCD Display: paso 5, imagen 1 de 3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: paso 5, imagen 2 de 3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: paso 5, imagen 3 de 3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 LCD Display Replacement: paso 6, imagen 1 de 3 Microsoft Lumia 435 LCD Display Replacement: paso 6, imagen 2 de 3 Microsoft Lumia 435 LCD Display Replacement: paso 6, imagen 3 de 3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 LCD Display Replacement: paso 7, imagen 1 de 1
    • The display is very fragile, do the separation very carefully.
Conclusión
5 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,308 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,532 Guías creadas
2 comentarios
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Contestar
I am pretty sure he didn’t use ifixit stuff to fix the screen, lmao
mario rados - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,220
