Introducción
This shows how the remove the motherboard from the Kinect. All of the components of the Kinect run through the motherboard. If the Kinect wont turn on or a component isn't working it may be an issue with the motherboard not the component itself.
Partes
No se especificaron partes.
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
2 personas más completaron esta guía.
