Introducción
This guide shows how to remove the LED in the Kinect if it becomes damaged and stops working.
Qué necesitas
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
Gently pull the LED out of the front of the metal casing. It should slide out easily.
Casi Terminas!
Conclusión
