Introducción
The camera component of the Kinect has three different lenses used for various functions. If you tried cleaning the lens and it didn't fix your problem you should use this guide.
Herramientas
Partes
No se especificaron partes.
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
Gently pull the LED out of the front of the metal casing. It should slide out easily.
3 personas más completaron esta guía.
