Saltar al contenido principal
Microsoft Band Wrist Clasp Replacement
Qué necesitas
  1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: paso 1, imagen 1 de 1
    • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
  2. Microsoft Band Wrist Clasp Replacement: paso 2, imagen 1 de 1
    • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
  3. Microsoft Band Wrist Clasp Replacement: paso 3, imagen 1 de 1
    • Pull the two securing pins out of the rubberized part of the band.
Conclusión
Una persona más ha completado esta guía.
Chad Steese
Miembro Desde 02/02/15
256 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-34, Amido Winter 2015 Miembro de Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Miembros
6 Guías creadas
3 comentarios
where can I purchase the replacement part
jeepgirlutah - Contestar
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - Contestar
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 5,141
