Saltar al contenido principal
Microsoft Band Battery Replacement
Qué necesitas
  1. Microsoft Band Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
  2. Microsoft Band Battery Replacement: paso 2, imagen 1 de 1
    • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
  3. Microsoft Band Battery Replacement: paso 3, imagen 1 de 1
    • Gently pry up one edge of the battery with the plastic spudger.
  4. Microsoft Band Battery Replacement: paso 4, imagen 1 de 1
    • Remove battery from its compartment with your fingers.
Conclusión
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 17-34, Amido Winter 2015 Miembro de Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Miembros
6 Guías creadas
5 comentarios
where can i buy the battery?
chirac - Contestar
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon -
Will this be dangerous?
Rei zzstu Shiozawa - Contestar
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Contestar
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 11,958
