Saltar al contenido principal
Microsoft Band 2 Battery Replacement
Qué necesitas
  1. Microsoft Band 2 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: paso 2, imagen 1 de 1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: paso 3, imagen 1 de 1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: paso 4, imagen 1 de 2 Microsoft Band 2 Battery Replacement: paso 4, imagen 2 de 2
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: paso 5, imagen 1 de 2 Microsoft Band 2 Battery Replacement: paso 5, imagen 2 de 2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: paso 6, imagen 1 de 2 Microsoft Band 2 Battery Replacement: paso 6, imagen 2 de 2
    • Pry out the battery using the plastic opening tool.
Conclusión
20 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G5, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 Miembros
5 Guías creadas
14 comentarios
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Contestar
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Contestar
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Contestar
The only place i found was ebay:
ftlay - Contestar
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 32
Todo El Tiempo: 12,854
