Introducción
This guide will show you how to dissemble the microphone. Before you start you need to have a set of screw drivers (Philips head #00, #2, #0). To reassemble the microphone just reverse the steps.
For names of the microphone parts, please click below:
Microphone Parts' Manual
  1. Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
    • Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
  2. Separate the microphone into two pieces to reveal the internal shield cover. Separate the microphone into two pieces to reveal the internal shield cover.
    • Separate the microphone into two pieces to reveal the internal shield cover.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. By unscrewing in a clockwise motion remove the bottom base of the microphone. This should free up the bottom base so that it can be separated from the microphone.
    • By unscrewing in a clockwise motion remove the bottom base of the microphone.
    • This should free up the bottom base so that it can be separated from the microphone.
  5. Using the Phillips head (#2) screwdriver, remove screw directly above the battery by rotating counterclockwise.
    • Using the Phillips head (#2) screwdriver, remove screw directly above the battery by rotating counterclockwise.
  6. Using the Phillips head (#0) screwdriver to remove the black screw near the bottom of the microphone.
    • Using the Phillips head (#0) screwdriver to remove the black screw near the bottom of the microphone.
  7. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible.
    • Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible.
Conclusión
Documentos Adjuntos
Kefaya
Miembro Desde 23/01/14
343 Reputación
3 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 74
Todo El Tiempo: 3,202
