Saltar al contenido principal
Qué necesitas
  1. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Turn off the engine: paso 1, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Turn off the engine: paso 1, imagen 2 de 2
    • Before you begin, make sure the device is powered down and cool to the touch.
    • Flip the engine switch into the OFF position.
  2. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Disconnect the spark plug: paso 2, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Disconnect the spark plug: paso 2, imagen 2 de 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Drain the compressor tank: paso 3, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Drain the compressor tank: paso 3, imagen 2 de 2
    • Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
    • Ensure the tank is completely depressurized before starting repairs.
  4. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the pressure gauge: paso 4, imagen 1 de 1
    • Use a 7/16 inch wrench to loosen the nut securing the pressure gauge to the regulator housing.
  5. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 5, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 5, imagen 2 de 2
    • Remove the pressure gauge.
  6. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: paso 6, imagen 1 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: paso 6, imagen 2 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: paso 6, imagen 3 de 3
    • Fit an adjustable wrench to the black metal square on the hose side of the regulator.
    • Use a 3/4 inch wrench to hold the nipple in place.
  7. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 7, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 7, imagen 2 de 2
    • Push the adjustable wrench to break the regulator loose from the threaded nipple.
  8. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 8, imagen 1 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 8, imagen 2 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 8, imagen 3 de 3
    • Fit an adjustable wrench to the black metal square on the bracket side of the regulator.
    • Use an 11/16 inch wrench to hold the hose barb.
  9. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 9, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: paso 9, imagen 2 de 2
    • Break the hose barb fitting loose from the regulator.
  10. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the two regulator mounting bracket bolts: paso 10, imagen 1 de 2 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the two regulator mounting bracket bolts: paso 10, imagen 2 de 2
    • Use a 1/2 inch socket and wrench to remove the two bolts and accompanying nuts securing the regulator mounting bracket to the frame.
    • Don't forget to remove the two washers as well.
  11. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: paso 11, imagen 1 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: paso 11, imagen 2 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: paso 11, imagen 3 de 3
    • Lift the regulator off of the mounting bracket.
    • Use your fingers to unscrew and remove the mounting bracket from the regulator.
  12. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: paso 12, imagen 1 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: paso 12, imagen 2 de 3 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: paso 12, imagen 3 de 3
    • Unscrew the adjustable regulator from the hose barb.
    • Remove the regulator.
  13. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the regulator plug: paso 13, imagen 1 de 1
    • Use a 3/16 inch hex key to remove the plug from the regulator.
    • Only the regulator remains.
Conclusión
Kyle Smith
Miembro Desde 01/02/21
34,510 Reputación
123 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 184
