Saltar al contenido principal
Meta Quest 3 Controller Strap Replacement
Qué necesitas
  1. Meta Quest 3 Controller Strap Replacement, Controller straps: paso 1, imagen 1 de 1
    • First, you will want to pick up any of the controllers to begin replacing the wrist strap.
  2. Meta Quest 3 Controller Strap Replacement: paso 2, imagen 1 de 1
    • Adjacent to the controller's joystick is a white triangle button.
    • You need to press down firmly on the button to open the controller's battery compartment.
  3. Meta Quest 3 Controller Strap Replacement: paso 3, imagen 1 de 2 Meta Quest 3 Controller Strap Replacement: paso 3, imagen 2 de 2
    • Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
  4. Meta Quest 3 Controller Strap Replacement: paso 4, imagen 1 de 1
    • Grab the corresponding wrist strap for the controller you are working on.
  5. Meta Quest 3 Controller Strap Replacement: paso 5, imagen 1 de 2 Meta Quest 3 Controller Strap Replacement: paso 5, imagen 2 de 2
    • With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
  6. Meta Quest 3 Controller Strap Replacement: paso 6, imagen 1 de 2 Meta Quest 3 Controller Strap Replacement: paso 6, imagen 2 de 2
    • You can close the battery compartment using the new cover connected to the controller strap.
    • Closing the battery compartment can be frustrating because it is connected to the strap; I found it easier to slide the cover from the bottom to the top.
    • The new controller straps come with new battery compartment covers, so when you replace the straps, you will end up with spare parts.
  7. Meta Quest 3 Controller Strap Replacement: paso 7, imagen 1 de 3 Meta Quest 3 Controller Strap Replacement: paso 7, imagen 2 de 3 Meta Quest 3 Controller Strap Replacement: paso 7, imagen 3 de 3
    • Put the controller in your hands to see if you need to adjust the fit of the strap.
    • If Adjustments are needed, you can pull or push the strap through the clip's hole.
  8. Meta Quest 3 Controller Strap Replacement: paso 8, imagen 1 de 2 Meta Quest 3 Controller Strap Replacement: paso 8, imagen 2 de 2
    • Next, repeat steps 2-7 on the second controller.
    • As mentioned in step 6, you will have spare parts left over from the original wrist strap and battery cover. Store these parts somewhere safe if you ever feel like reverting to the original controller straps.
Conclusión
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
Una persona más ha completado esta guía.
Andrew28709
Miembro Desde 10/18/23
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 47
Ultimos 30 días: 201
Todo El Tiempo: 1,488
