Introducción
Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
Qué necesitas
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
Once the ribbon cable is disengaged gently pull the cable off the motherboard.
Casi Terminas!
Conclusión
3 comentarios
Was wondering if you could help me identify a microchip on the board by the speaker?
mine acts like it does not recognize the rca cords. help
