Saltar al contenido principal
Introducción
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
Herramientas
Partes
No se especificaron partes.
  1. Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver. Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Using your hands, gently pry the top and bottom of the projector casing apart. Using your hands, gently pry the top and bottom of the projector casing apart.
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Remove the light bulb from its housing unit. Do not damage the 2 white cables leading into the light bulb panel. Do not damage the 2 white cables leading into the light bulb panel.
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb. The light blub is held into the socket with prongs, and should easily pull straight out.
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
Conclusión
Una persona más ha completado esta guía.
Stephanie
Miembro Desde 08/01/15
276 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-3, Maness Winter 2015 Miembro de Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Miembros
4 Guías creadas
Un Comentario
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 1,190
