Introducción
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
Herramientas
Partes
No se especificaron partes.
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Una persona más ha completado esta guía.
