Introducción
That's right, there is another filter in the tank on your W123! Mercedes didn't think it was enough to have a fuel pre-filter, and a large spin on filter. They also chose to install a fuel strainer at the main outlet for the fuel tank to keep large particles out of your W123's fuel system. This often ignored item can become clogged enough that it 1) slows fuel flow to your engine, lowering power output 2) becomes clogged up to a certain point on the screen so that it effectively lessens the volume of your fuel tank since fuel below that line cannot pass or 3) become so clogged that it prevents fuel from flowing at all potentially leaving you stranded. Or, you might remove it only to find it's perfectly clean! But you won't know until you do it.
The fuel strainer is a pretty hardy part and usually can be cleaned, rather than replaced with a new part.
A good time to perform this work is when you have already drained the tank to replace the rear fuel lines.
Herramientas
Partes
No se especificaron partes.
Before proceeding to the first step of the removal of your tank strainer you will need to drain your fuel tank and remove the main fuel feed line that screws in to the body of the tank strainer. See the rear fuel line replacement guide for guidance on this process.
Now you will have access to the tank strainer. It screws directly in to the bottom of the fuel tank.
You may find that around the strainer there is some rubber lining that sits under the fuel tank. You may need to trim a bit of this rubber out of the way in order to have better access to the strainer.
Use a large socket (size 1 and 13/16") to remove the strainer. Access is tight up above the rear axle on this side of the car. You may need to improvise a bit. I used this modified socket that has a 17mm nut welded to the bottom, and a pair of vice grips. If you have a 3/4" drive socket wrench you can use this type of socket without modification.
The strainer will simply screw out, after breaking it loose with the socket. Screw it out gradually. As you loosen it, fuel will begin to flow past it - there is going to be about 8oz to 12oz still in the tank. Slowly continue to loosen the strainer, letting the fuel drain as you proceed. Do not remove it in a hurry or risk getting a fuel shower!
Here is an example of what is possible for you to find when you remove the strainer. This car probably was not running when the strainer was removed.
Note - if you find more than a small amount of debris, consider running a biocide in your fuel tank, following the manufacturer's instructions for use. This amount of debris is likely from a microbial infection of the fuel.
Back to the tank strainer removed from this car. It was lightly cleaned with some brake cleaner, but again, not much was needed.
One more item to consider addressing with the strainer out is the o-ring seal at the base. It was rather flat and hardened on this strainer. Replacing it gives peace of mind that you will not need to remove the strainer again for some time.
To reassemble your device, follow these instructions in reverse order, replace the main fuel feed line, and refill the fuel tank.
10 personas más completaron esta guía.
4 comentarios
Do you need to bleed the system after doing this?
Ryan, no, you do not. This is on the non-pressurised side of the system, gravity fed. No need to bleed it.
