Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The injector hard lines deliver fuel from the injection pump to the injectors are very high pressures; well over 1000 psi! The smallest hair line crack in the metal line will lead to fuel leaks. In such a situation they will need to be replaced.
Beyond that, not much goes wrong with the hard lines, but it's good to learn how to remove and install the lines so you can pull them off to more easily do other jobs like replacing your glow plugs.
Herramientas
Partes
  1. Begin by marking the hard lines. Each one goes in only one location, it will make it easier to re-install the lines or to install your new lines if you mark where each shaped line goes on the injection pump/injectors.
    • Begin by marking the hard lines. Each one goes in only one location, it will make it easier to re-install the lines or to install your new lines if you mark where each shaped line goes on the injection pump/injectors.
  2. Then begin removing the clamps that hold adjacent hard lines together. You'll use a 8mm socket on top of the bolt that holds the clamps together, and a 8mm box end wrench on the bottom nut that the bolt goes in to.
    • Then begin removing the clamps that hold adjacent hard lines together.
    • You'll use a 8mm socket on top of the bolt that holds the clamps together, and a 8mm box end wrench on the bottom nut that the bolt goes in to.
    • Go slowly with this and be careful to not drop the nuts or clamp pieces as they can fall behind the injection pump. It's not impossible to get them out, but it can be difficult.
    • The second picture shows the hard lines with all of the clamps removed. Be sure to re-install all of the clamps on the lines; they help prevent the lines from vibrating excessively. The vibration is what tends to cause them to crack!
  3. Now, use a 17mm wrench loosen the rear-most nuts on the hard lines at the injection pump. Then, use the same wrench to loosen the nut on the same hard line at its respective injector.
    • Now, use a 17mm wrench loosen the rear-most nuts on the hard lines at the injection pump.
    • Then, use the same wrench to loosen the nut on the same hard line at its respective injector.
  4. You can then remove that hard line.
    • You can then remove that hard line.
    • Proceed in the same manner for the other lines until all are removed.
  5. While your hard lines are off, cover the hard line fittings on the pump as well as at each injector to prevent contamination from entering. The injector nozzles have very small openings that can be easily clogged.
    • While your hard lines are off, cover the hard line fittings on the pump as well as at each injector to prevent contamination from entering. The injector nozzles have very small openings that can be easily clogged.
Conclusión
4 personas más completaron esta guía.
Nicolas Siemsen
Miembro Desde 06/12/13
35,226 Reputación
79 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
295 Miembros
974 Guías creadas
Excelente Guia Muchas gracias!!!
Pippenpy - Contestar
do you need to bleed the lines after you put them back on?
john umbanhowar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 43
Todo El Tiempo: 9,158
