Introducción
Quitar el cenicero en un W123 es fácil, pero el método no es inmediatamente obvio. Esta guía te mostrará cómo. Además, aprenderá cómo quitar la placa de respaldo en la que se encuentra la bandeja de cenizas en caso de que necesite obtener un mayor acceso al área detrás de ella.
Qué necesitas
Para volver a armar , siga estas instrucciones en orden inverso.
14 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ farlafiada nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
4 comentarios
What would be the purpose of removing ashtray ?
It provides access to the portion of the center console behind the ash tray. There is wiring back there. It can also help with the removal of the shift gate panel.
Removal of ashtray is also necessary to access the lamp which illuminates the cavity. After taking ashtray out, remove two Philips (+) screws, then separate metal cover from plastic housing. Next to the lighter housing is light socket. It holds a 12 volt, 2 watt, T2 bayonet base, #1272 lamp. Push, then twist lamp to remove. Clean copper terminal at side of socket as well as moving contact on side of ashtray housing. This lamp is same type as used for automatic shift indicator. This is one of the most overlooked lamps in a W123 chassis. Tip: while metal cover is removed, clean and scrub ashtray, it is much easier to access this way.
