Saltar al contenido principal
Memorex CD Alarm Clock Radio PCB Board Replacement
Qué necesitas
  1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 1 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 2 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 3 de 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio PCB Board Replacement: paso 2, imagen 1 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement: paso 2, imagen 2 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement: paso 2, imagen 3 de 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio PCB Board Replacement, PCB Board: paso 3, imagen 1 de 1
    • Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
    • Using a magnetic tip screwdriver will prevent screw loss.
  4. Memorex CD Alarm Clock Radio PCB Board Replacement: paso 4, imagen 1 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement: paso 4, imagen 2 de 3 Memorex CD Alarm Clock Radio PCB Board Replacement: paso 4, imagen 3 de 3
    • Locate the wiring harness.
    • Disconnect the wiring harness using the tweezers.
  5. Memorex CD Alarm Clock Radio PCB Board Replacement: paso 5, imagen 1 de 1
    • Remove the PCB board from the device.
    • Replace the broken motherboard with a new PCB board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 325
