Saltar al contenido principal
Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement
Qué necesitas
  1. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement, CD Cover Latch: paso 1, imagen 1 de 1
    • Open the CD cover so that the latch can be accessed.
  2. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: paso 2, imagen 1 de 1
    • Using a 3/16" flat head screwdriver, gently pry in the corner of the latch and the boombox housing.
    • You should see the latch pop out of the housing a little bit.
    • Then move to the opposite side of the latch and gently pry there.
    • Keep moving back and forth until the latch comes loose and can be removed with your fingers.
  3. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: paso 3, imagen 1 de 1
    • When the latch is removed, it should like the part in the picture.
Conclusión
Meghan
Miembro Desde 10/16/14
579 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-4, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-4, Duarte Fall 2014
UMASSD-DUARTE-F14S2G4
4 Miembros
6 Guías creadas
2 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 2,204
