Saltar al contenido principal
Megawheels S10 Rear Mudguard Replacement
Qué necesitas
  1. Megawheels S10 Rear Mudguard Replacement, Rear Mudguard: paso 1, imagen 1 de 1
    • Hold down the power button and wait for a beep to ensure that the scooter is turned off.
  2. Megawheels S10 Rear Mudguard Replacement: paso 2, imagen 1 de 1
    • Put up the kickstand so that the scooter is upright.
  3. Megawheels S10 Rear Mudguard Replacement: paso 3, imagen 1 de 1
    • Unscrew the old mudguard.
  4. Megawheels S10 Rear Mudguard Replacement: paso 4, imagen 1 de 1
    • Grip the wheel and pull off the mudguard.
  5. Megawheels S10 Rear Mudguard Replacement: paso 5, imagen 1 de 1
    • Remove the connector.
  6. Megawheels S10 Rear Mudguard Replacement: paso 6, imagen 1 de 1
    • Attach the new mudguard's power connector.
  7. Megawheels S10 Rear Mudguard Replacement: paso 7, imagen 1 de 1
    • Line up the new mudguard with the screw holes and reinsert the screws.
Conclusión
If these steps are followed correctly, then your manual break and tail light should function good as new!
Andrew DiCapo
Miembro Desde 09/28/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 36
Todo El Tiempo: 832
