Saltar al contenido principal
Medion Akoya MD 98560 Heat Sink Replacement
Qué necesitas
  1. Medion Akoya MD 98560 Heat Sink Replacement, Heat Sink: paso 1, imagen 1 de 1
    • Remove the battery by sliding both sliders to the left.
    • Hold the left slider as you slide the battery away from you.
  2. Medion Akoya MD 98560 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Press and hold the power button for 10 - 15 seconds, to release any excess power from the laptop.
  3. Medion Akoya MD 98560 Heat Sink Replacement: paso 3, imagen 1 de 1
    • After removing the battery, undo the single screw holding the RAM compartment lid.
    • Gently pop out the lid with a few clicks.
  4. Medion Akoya MD 98560 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Undo the white and black cable, and the screw.
    • Lift the wifi board up and away from you.
  5. Medion Akoya MD 98560 Heat Sink Replacement: paso 5, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 5, imagen 2 de 2
    • Pry the metal clips holding the RAM units outward which will make the uint pop upwards.
    • Slide the unit out, towards you.
  6. Medion Akoya MD 98560 Heat Sink Replacement: paso 6, imagen 1 de 1
    • Undo the single screw holding the hard drive lid.
  7. Medion Akoya MD 98560 Heat Sink Replacement: paso 7, imagen 1 de 1
    • Undo the single screw holding the hard drive.
  8. Medion Akoya MD 98560 Heat Sink Replacement: paso 8, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 8, imagen 2 de 2
    • Use the black tab to slide the hard drive backwards.
    • Pry the hard drive up, on the far side and it slides out.
    • Be careful when prying the hard drive out of the case, you might drop it and damage it.
  9. Medion Akoya MD 98560 Heat Sink Replacement: paso 9, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 9, imagen 2 de 2
    • Push the 4 black tabs located at the top of the keyboard, under the case.
  10. Medion Akoya MD 98560 Heat Sink Replacement: paso 10, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 10, imagen 2 de 2
    • Be careful when removing the keyboard from the case, it is still attached at the bottom.
    • Pry the black tab backwards, to remove the cable.
  11. Medion Akoya MD 98560 Heat Sink Replacement: paso 11, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 11, imagen 2 de 2
    • On the bottom of the case there are 2 sliders, use these to release the optical drive.
  12. Medion Akoya MD 98560 Heat Sink Replacement: paso 12, imagen 1 de 1
    • Undo the 11 screws holding the bottom of the case.
  13. Medion Akoya MD 98560 Heat Sink Replacement: paso 13, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 13, imagen 2 de 2
    • Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case.
  14. Medion Akoya MD 98560 Heat Sink Replacement: paso 14, imagen 1 de 1
    • Pry open the case using something soft, preferably your hands or a spudger.
  15. Medion Akoya MD 98560 Heat Sink Replacement: paso 15, imagen 1 de 1
    • When the case is completely lose it will still be attached by the "MB" cables. Remove those before completely removing the case.
  16. Medion Akoya MD 98560 Heat Sink Replacement: paso 16, imagen 1 de 1
    • Undo the single screw holding the motherboard.
    • Undo the 4 cables highlighted in blue.
  17. Medion Akoya MD 98560 Heat Sink Replacement: paso 17, imagen 1 de 1
    • Also remove the black and white wifi cable from under the motherboard.
  18. Medion Akoya MD 98560 Heat Sink Replacement: paso 18, imagen 1 de 1
    • Lift the motherboard out of its socket. The bottom left may get stuck a bit. Don't force the USB sockets.
  19. Medion Akoya MD 98560 Heat Sink Replacement: paso 19, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 19, imagen 2 de 2
    • On the flipside of the motherboard is the CPU covered by the heatsink.
    • Before removing the heatsink, remove the fan cable looping over the heatsink.
    • Remove the 6 screws, holding the heatsink.
  20. Medion Akoya MD 98560 Heat Sink Replacement: paso 20, imagen 1 de 1
    • First you will need a card to scrape off the old paste. Keep a coffee filter ready to clean the card.
    • Both the heatsink and CPU's must be totally cleaned of any remaining grease.
    • The triangular part on the heatsink leads to the graphics card.
  21. Medion Akoya MD 98560 Heat Sink Replacement: paso 21, imagen 1 de 1
    • Be very thorough, any remaining grease may render your new layer of paste useless.
    • The top cores are the CPU, still not cleaned.
    • The bottom core is the newly cleaned video card CPU.
  22. Medion Akoya MD 98560 Heat Sink Replacement: paso 22, imagen 1 de 2 Medion Akoya MD 98560 Heat Sink Replacement: paso 22, imagen 2 de 2
    • Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth.
    • Apply the paste on the CPU's very carefully, you don't want certain thermal pastes on electrical circuits.
    • Your paste needs to be distributed evenly on the whole metal cap of the CPU.
    • Reverse engineer this guide to put the laptop back together.
    • Let the paste settle in by letting the computer run for a few consecutive hours.
    • Run a temperature monitor software to check if your application has been effective or not. After a day or two, you may want to stress-test it by running some high end application all together and monitor the temperature.
Conclusión
9 personas más completaron esta guía.
Ikfixda
Miembro Desde 07/03/11
465 Reputación
1 Guía escrita
3 comentarios
Diese Anleitung zum Öffnen und Ausbauen des Kühlers ist ebenfalls anwendbar für das Medion Akoya P6624 (MD98390)
Lutz - Contestar
works for some other Aldi Akoya models too! quite versatile.
ein Stein - Contestar
this disassembly is required to access the knob cell . remove knob cell and do a BIOS full reset for a proper RESET. still UEFI variables in NVRAM may have gone haywire, thus killing the laptop machine.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 47
Todo El Tiempo: 14,274
