Saltar al contenido principal
Maze Speed SSB-508 Power and Volume Button Replacement
Qué necesitas
  1. Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: paso 1, imagen 1 de 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: paso 1, imagen 2 de 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: paso 1, imagen 3 de 3
    • Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
  2. Maze Speed SSB-508 Power and Volume Button Replacement: paso 2, imagen 1 de 2 Maze Speed SSB-508 Power and Volume Button Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
  3. Maze Speed SSB-508 Power and Volume Button Replacement: paso 3, imagen 1 de 3 Maze Speed SSB-508 Power and Volume Button Replacement: paso 3, imagen 2 de 3 Maze Speed SSB-508 Power and Volume Button Replacement: paso 3, imagen 3 de 3
    • Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 318
